D.Hearne
Her's my .02 worth: Yea the 8.8 will handle morethan some think, but to build one to fit an early Stang, will cost you the same money a 9" will. I bought an Exploder 8.8 a couple years back, paid $100 for the complete deal. By the time I added Strange axles to match the 9" bearing ends (I don't trust C clips or eliminators) and narrowing to 52" to tuck the 10" wheels under the Ranger, I had $800 in it. One other tip, don't order the 7.5" or Stang 8.8" brake pattern 9" style ends. I ended up with these by mistake (that's another story) and I've had nothing but grief from them. The bolt pattern for the brake plates is too small for it to use thru bolts and nuts to retain them and they have a threaded hole in the housing. That combined with the tapered roller bearings (another bad idea for axles) are the biggest PITA that I've ever seen. The tapered bearing's always got the brake plate bolts under a strain and I've had em get loose several times.
I've been sitting on a 9" 3.50 T-Lok center section for over a year now and I finally have something to put it in. My engine combo works so-so with the 3.00 8", but boy is it going to be happier with the 3.50s.
