There's all sorts of assumptions about what is and what is not, in regards to the differences between Ford 8- & 9-inch rear ends, but the primary assumption is that the 9-inch rear is
drastically heavier than an 8-inch. In reality, a '57-'59 Ford small bearing drum brake 9-inch rear assembly is only 24 lbs. heavier than a comporably equipped '65/'66 Mustang 8-inch rear.
That equates to only 12 lbs. per side heavier, which to me, isn't what I would consider a significant margin. If the rear end was 50 or 75 lbs., over all heavier, then that to me would be a significant amount.
I don't know of any Ford-produced 8-inch differentials that came with 4-pinions (spider gears). There are aftermarket 8-inch differentials (such as from Curries) that have 4-pinion setups, but I've never seen any 8-inch diffs from the factory with them installed.
The 9-inch, on the other hand, could have either 2- or 4-pinion setups.
Here are some rear end/rear end parts weight comparrisons:
FORD REAR END WEIGHT COMPARISON 8
8-inch Rear End Assembly Weight : 170 lbs.
1. Housing: 36 lbs.
2. Axles: Medium Journal, 28-spline -15 lbs. ea.
3. Brakes: Small 10" x 1¾" Drum Assemblies - 22 lbs. ea.
4. 3rd Member: Reinforced Revision 8-inch Case - 60 lbs.
9-inch Rear End Assembly Weight: 194 lbs.
1. Housing: 38 lbs.
2. Axles: Large Journal, 28-spline - 18 Lbs. ea.
3. Brakes: Massive 11-1/32 x 2½" Drum Assemblies - 26 lbs. ea.
4. 3rd Member: Conventional Diff. - 68 lbs.
a. w/Traction-Lok Diff. - 71 lbs.
(24 lbs. Difference Between Drum Brake 8" & Drum Brake 9" Rear End Assembly).
Versailles Disc Brake Rear End Assembly Weight: 215 lbs.
1. Housing: 39 lbs.
2. Caliper: w/Pads, Anchor Plate & Flexible Brake Hose - 24 lbs. ea.
3. Axles: 20 lbs. ea.
4. Rotors: 10 lbs. ea.
5. 3rd member: Conventional Diff. - 68 lbs.
(45 lbs. Difference Between Drum Brake 8" & Disc Brake 9" Versailles).
Wheel/Tire Comparison:
1. Stock '66 Mustang GT Styled Steel Wheel w/ P195/70R-14 Tire - 46 lbs. ea.
2. Weld Draglite Forged Aluminum Wheel (15" x 8") w/ P245/60-15 Tire - 38 lbs. ea.
Miscellaneous:
1. 8" Drum Brake Assembly: (10" x 1¾" Drums): 22 lbs. ea.
2. 9" Drum Brake Assembly (11-1/32" x 2½" Drums): 26 lbs. ea.
3. Lincoln Versailles Disc Brake Assembly: (10½" Rotors) 30 lbs. ea.
4. Lincoln Mk VII Rear Disc Brake Rotor/Caliper Assembly Weight: (11¼" Rotors) 22 lbs.ea.
5. Ford Explorer Rear Disc Brake Rotor/Caliper Assembly Weight: (11¼" Rotors) 25 lbs. ea.
www.ultrastang.com
