My 8 inch rear has stood up to some abuse, but I wanted to know who has broken one, where did it break(casing, pinion suport, axl, ring, pinion, yoke), what hp/tq were you pushing, what trans(stick, auto), and what were you doing(side steping the clutch on slicks at 6000rpm).
Currie makes an aluminum casing(alumin8) for the 8 that is stronger and lighter than the stock, plus they make an alumim pinion suport that has a bigger bearing adding more strength. I was hoping most of the issues of breaking involved the case, pinion support, and or axles(since I upgraded to better ones).
thanks for any info
thanks for any info
