80cc Heads
  • Thread starter Thread starter Shaolin Crane
  • Start date Start date Nov 26, 2009
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Nov 26, 2009
  • Nov 26, 2009
Is there a company out there that makes an 80cc combustion chamber head for a SBF? or if the head manufacturers would do a custom job and make me a set of head with an 80cc combustion chamber? all help is appreciated
srtthis
the guy doing it does every local racers rear end
5,129
1,666
204
Maryland
Nov 26, 2009
  • Nov 26, 2009
biggest afr is 72
biggest trick flow is 70
biggest brodix is 68
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Nov 26, 2009
  • Nov 26, 2009
Posted via Mobile Device
Next question is why in the hell, would you need an 80cc head?
srtthis
5,129
1,666
204
Maryland
Nov 26, 2009
  • Nov 26, 2009
my guess would be a change of direction to lower compression with out haveing to get new pistons...
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Nov 26, 2009
  • Nov 26, 2009
True, but that should only be for a boosted application, technically. Many ways to get around a higher compression with boost. More than likely cheaper than buying a new set of head and having the chamber re-done.
Unless he has a set of heads like the AFR's with the 72cc , then 8cc is do-able in the chamber. Most guys dont have the compression they think they have.
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Nov 26, 2009
  • Nov 26, 2009
I was doing calculations last night for my new engine, and as far as i can see my static compression ratio is going to be 9.46:1 and that a tad higher than i want for boost, for some reason now i cant remember why i went with these pistons for a boosted application, my guess was the price i got on the entire kit
unless im doing my math wrong
-4.0cc flat top pistons
3.4" stroke
5.4" rod
MLS gasket thickness .040"
for my boost application i'd like something closer to around 9.0:1 or less, hence why i would like a large combustion chamber head
and no i dont have the heads yet thats why i was asking
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Nov 26, 2009
  • Nov 26, 2009
Do you know how far the piston is in or out of the bore? And what the headgasket bore diameter is? You also have to account for the ring land being below the top of the piston. Most guys dont, and thats why I said that most guys dont have the compression they think they have. It usually a little less.
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Nov 26, 2009
  • Nov 26, 2009
piston sits completely flush at the top of each bore, headgasket bore diameter is 4.040 at .040 thickness
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Nov 26, 2009
  • Nov 26, 2009
The Dynamic Compression ratio is going to be lower. Has everything to do with the cam. In other words, if you had a CR of 9.5:1 with one cam, then switch cams that had a different Intake valve closing, then the amount of cylinder pressure could be different, resulting in a Dynamic compression ratio lower. The DCR is what the engine actually sees. Static Compression is just a calculated number.
On the static compression, I came up with the same as you did. So your math was right.
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Nov 26, 2009
#10
  • Nov 26, 2009
  • #10
Also factor in that the pistons may say -4cc. Ive heard some measuring out to be 7cc. They can often be more than advertised. Then add in the space between the piston and cylinder wall above the top ring land thats about 2.5cc depending. You could very well have 5-7cc more in that alone. Which should put your static compression in the range you are looking for if thats the case. Thats with the AFR head with a 72cc chamber.
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Nov 26, 2009
#11
  • Nov 26, 2009
  • #11
the probe **** is pretty dead on i can easily clay fill or silicone fill the relief cuts to see what they are exactly
Engine (EGR Deleted) Solution the hotter combustion chambers?
  • PonyGTrider
  • Jan 21, 2026
  • 3 4 5
4K
Fox 5.0 Mustang Tech May 2, 2026
PonyGTrider
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
9
Milton Questions, 351 swap newedge
  • 996stang
  • Jul 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 25, 2026
Killer351w
K
