83 turbo coupe miss firing
redman9678
I have an 83 turbocoupe and after getting wild with it one night, when I Shifted to second gear it sputtered and lost power. Im pretty sure I didnt over tach it. With the engine running at idle It seems fine.But when i give it gas it sounds as if it is back firing through the air intake ( Filter )
I have checked the timing and that is fine. I checked the cap and rotor and that looked fine. I checked the spark plugs fine.Replaced the catalatic converter. checked the alignment on the camshaft fine
Any help would be greatly appreciated by the way its a 2.3 liter turbo thanks
air filter and fuel filter is new
Now im having a problem that it will not start. I can smell the gas . it is getting spark air filter is removed . it just keeps cranking and cranking
