'86 HO vs. '87 - '93 HO
  • Thread starter Thread starter mapandjlp
  • Start date Start date Apr 12, 2009
M
mapandjlp
York, PA
Apr 12, 2009
  • Apr 12, 2009
So, I've been reading about the differences in the heads and pistons in the '86 5.0 HO motor. Have any of you modded an '86 motor? Can I just update to the newer pistons with the valve reliefs to be able to run the aftermarket heads/bigger camshafts? Is there anything special on the '86 motot that I should consider other than the pistons?
Thanks!
Vinnietbird
584
  • Apr 12, 2009
The pistons are FLAT.I have those pistons in my engine and I swapped the E-6 heads (which are on the '86) for E-7's.I also use an E303 cam.....but I am probably one of the lucky ones to get away with that.Swap the pistons and heads,then go crazy.You may need to do a Mass Air upgrade as well if you plan on a bigger cam.I did that as well,easy stuff.
M
mapandjlp
York, PA
Apr 12, 2009
  • Apr 12, 2009
Yeah, that's what I've been told. Seems like you are a lucky one if you've not had any trouble. Although, I have heard of others swapping on the E7s with no trouble.
So there's no problem with changing out the pistons to the newer, notched versions? As long as that's the case, I'm golden!
Oh, and it's already been upgraded to MAF.
Thanks for the feedback!
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
A
Fox Planning on building my foxbody and was wondering if I can get any tips or anything to watch out for!
  • Angelq1028
  • Oct 31, 2024
  • 2 3 4
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 29, 2025
Robman8028
R
