the 87-93 drive shafts are shorter then ours right? i would need an spacer to make it fit properly.. where can i buy one?
urban96 said:is the wheel base the same? maybe the fox is a lil shorter. or maybe its in the k-member
mricci said:where can you get one of these spacers from?
miller92063 said:the fox body transmission setup is 5/8 shorter thab ours. the ford racing aluminum d/s is for 87-95 automatic or manual. yes the fox wheelbase is shorter.
miller92063 said:you technically do not need a spacer for the tko's, but it is better to have the input shaft in all the way!
DarkProphet said:They are the SAME length. The input shaft on our tranny is longer too, which moves the tranny back I believe. the alum driveshaft will fit perfectly if your using a stock tranny, thats for sure, not sure about other trannys as I only have the stock one.
