I would just like to say hi to everyone here first as I just bought the first mustang I have had in awhile and joined here hoping to be able to fix it up some. The car is a 1987 GT 5.0 5 speed hatchback. It has a few issues that need to be worked out starting with the transmission.
When I drive it down the road it is fine going into and out of 1st gear but 2nd, no matter if it goes into gear or not, has a little grind. Sometimes it doesn't go into 2nd but I can get it most of the time if I drive/shift a little harder. I was thinking the synchros are the problem but I tried letting the rpm's drop and shifting and it still grinds. I read up some before this and heard to put Dexron 4 in it but these ****ty car parts places only had a couple choices and the best seemed to be Mobil 1 ATF Synthetic which one of the guys working there said it was the same just from the Mobil brand.
I drained the transmission and put the new oil in but even after I did there doesn't seem to be much of a difference. Now that I have joined here and read more it seems maybe I shouldn't have got synthetic? Anyways, I am thinking I will end up needing a transmission but I wanted to get a good idea of the issue in case there was a easy fix. Also, if it is a synchro or something in the tranny how long could I count on it lasting for until I have no 2nd at all? I hate to ask that but I will probably have to save up $400-500 by the looks to get a used one off ebay which doesn't seem like to bad of a deal, it will just take me awhile. Thanks for any help :SNSign:
