Electrical 87 GT - Want Stock Tachometer to work with MSD Ignitiion
njmatt415
11
NJ
Hi All,
Working with an 87 Mustang GT T-Top here. This car came with an MSD ignition which works great. It also came with a shift light that was never hooked up (and never will be). What I'd like to do is get the stock tach working on this fox to restore the retro feel. Please help! What is needed to get the stock/factory tachometer hooked up to the MSD? I did read that the MSD Tach Adapter 8920 is not required for my year. I'm not sure if this is true. If anyone could tell me how/where to hook up to the tach that would be awesome! Thanks.
matt
Thanks. I assumed the MSD was involved since all these adapters are floating around. I've since found the following info:
Tach Wire: Dark green with yellow stripe wire at ignition coil
thats the first thing you should have mentioned... how much of the factory wiring is still remaining?? the tach is pulsed from the negative side of the stock coil. If the wiring is no longer there you will have to take the tach out from the MSD or the negative coil wiring and extend it to where the factory wiring was cut.
Reactions: njmatt415
Thanks. I was able to locate the signal using an external tach to the ignition coil and is steady! So now I would just need to run a wire from the negative side of the coil to the green and yellow stripe wire?
