88 5.0 with moates quarterhorse and wide band 02
notchback10s
i have a 1988 notchback rebuilt 5.0 with heads, cam 512 lift, dual valve springs, upper and lower intakes, cai, 24lbs injectors, long tube heads, built t5 build 8.8 with eaton posi, wide band o2 kit, moates quarter horse, now my question is how do i install the wide band? do i keep both stock o2 in and put the wide band o2 in another spot? or do i just put the wide band in where the stock one was and just hook up the one stock one i am new to tuning so any help with using the wide band or the quarterhorse would be great
You need to install a bung in your crossover pipe. Whether you have a X or an H.
Are you running the WB through the EGR circuitry for the quarterhorse?
You might ask the guys over on eectuning about how to set everything up.
Good luck
