Okay, so our 5.0/AOD combo is running super rich at low rpms.
We dyno'd it the other day, and on every pull it started at 10:1 AFR, and gradually rose until 6k rpms where it peaked at 13:1.
It was a steady rise, not any sort of quick change.
Just a 45* line from 10 to 13, 2k rpm to 6k rpm.
So it is pig rich down low, then gradually leans out to redline.
The dyno operator said the line should be flat, not a 45* slope.
The shop says the only way to clear it up is with a $450 tune (plus initial $250 buy in of a specific chip set they use to interface with the ECM)
Can't afford that!
I can think of a thousand ways to lean out the engine, but the fear is that if we lean out the bottom end, and the AFR slope stays the same, it will lean out the top end to a dangerous level.
One would hope that we could lean out the bottom, and the ECM would see the top getting too lean and richen it out. ??? IDEAS?
Can't afford that!
