89 hatch brakes
micheal
i am looking into doing a 5 lug swap on my 89 hatch and there is a 2002 mustang being parted out locally could i use any parts from the 02 like axle shafts front spindles ect..??
You can't use the axles because they are about 1.5 inches longer each. You can use the the caliper brackets and hardware for sure and I believe u can use the calipers and rotors but I'm not 100 percent on this. Someone will chime in and clarify it though.
from the 02 the only thing you will want is the front/rear calipers and brackets. Ideally for a 5 lug swap on a fox you want the spindles/hubs and axles from a 94-95 car. or the axles from a ranger. There is a massive sticky on this at the top of the page.
