90-93 Cluster in a 89
4Jenna
4,326
AZ
Hey guys I'm not to sure a 90-93 Speedo cluster will work in my 89. I have read that the non airbag cars have to use one of those speedos..can anyone verify?
I was taking my cluster out last night (140mph) out of my 89 because my fuel guage isn't working, and to my suprise I think mine is a 90-93 cluster. Mine doesn't have the idiot lights on the lower right corner...hmmmm
So I guess this means I CAN run a 90-93 cluster.
HMMMMMM
Chris
Don't think the 89's had the light in the bottom croner, like the 87-88's. A newer clust won't work in you car with some modifications. mainly swapping the plastic circut panel. Did it, on an 87 coupe when doing a 4cyl to 8cyl swap using all 92 interior. I tried a newer style cluster in my 88 once and it didn't work. When doing the 4cyl conversion we used the 92 cluster but put the circut panel form an 87-89 on it and had no problems..
Glad you got it fixed. You can tell the difference between the clusters immediately by the bottoms. 87-89 are flat across the bottom, while the 90-93 have an arch cut out above the steering wheel.
