90 convert update
Stableboy
91
Perryville MD
OK..after replacing a bent valve and a bad head gasket..she lives. However I have two problems left. The first is that it needs a radiator. I can see coolant bubbling out on two places where the fins meet the tanks (one each side). What is an average price for a radiator? I have bought a radiator for a diff car from a junkyard and had no problems. Should I buy new or look salvage?
Second problem. After approx 15 minutes the check engine light comes on. Car doesn't run any differant. If I shut her down and restart the light stays off for about another 15 minutes. Any guesses where to look first?
Radiator prices are going sky high. Even at the junkyards. The price for copper and brass and aluminum is really high so anywhere you go, you'll be shelling out the big bucks. I got a cheap aluminum radiator for my 88 at NAPA a few months ago for around 200. Good copper core ones can go upwards of 300 bucks now. I would always buy a NEW radiator, but that is personal opinion there. As for the check engine light, the easy way to tell what's going on would be to run the codes. If you're not sure how, a Chilton/Haynes manual will tell you how. Sounds like something isn't working once the car is warmed up. Could be a multitude of things, but since it drives fine, I would almost suspect an EGR fault. That would only cause it to ping a little and the computer to pull back the timing a little. Easy way to check if that system is working is to drive for a while and then when you get home, carefully touch the egr pipe near the valve. If it is flaming hot, the EGR system is most likely working. If it is only as hot as your intake, then it's probably not working. But, running the codes would reveal the trouble quickly.
I put a junkyard one in my car when I replaced the water pump and it lasted about six months. I then bought one at Autozone for $88. It is aluminum and plastic but comes with a lifetime warranty. If your car is stock like mine you shouldn't have any problems.
OK....new radiator in 175 at pepboys, used buddies account paid 84 bucks..in like a charm, check engine light did not come on after shake down run (same run I always use) could the two have been connected..something like cooling system couldnt pressurize due to leaks or something?
I used to have a sticky egr valve that would randomly throw a code when the car would get warm. Some days it would, some days it wouldn't. Cooling system components generally don't throw many codes unless a sensor is bad. Since you only replaced the radiator and no sensors, my guess would be that the CEL will be coming on again soon. or perhaps the radiator is magical? : P
