Ok, so as you guys may or may not know, Kenne Bell specifically recommends using only their 90mm MAF and big tube setup with their 99-04 kit. They also say the OEM maf is pegged at around 408rwhp..
Here's my question.
Are any of you 9psi KB guys using another MAF, say the 90mm Lightning/Cobra MAF, without modifying the KB tune? If so, are you having any problems? Is there even a difference between the "KB" MAF and the cobra MAF, or is it the same thing? Also, isn't the lightning MAF calibrated for 42 pound injectors? The KB kit uses 36#, so what's the trick around that?
Here's my question.
