Swarzkopf said:If you're swapping to a V6, why not swap to a V8?
Seems to me that the turbo 2.3 makes the most sense by far.
Well first the 99 and up V6's have just as much power as the stock 5.0's and 2.3 turbos did back in the day (10-20 hp diff max).
Second the V6 gets about the same mileage as the 2.3 and a lot better then the 5.0 and with gas $3 a gallon I am not wanting a gas hog.
The V6 seems to be the best compromise to me. Plus I wont have to buy a 8.8 rear, or do much to the brake system.
Electrical shouldnt be any more difficult then transplanting any other engine just have to get the main engine harness and ECM along with the engine.
Not to mention I can get a engine with auto tranny for under $700.
Swarzkopf said:190hp compared to 225hp...and that's PEAK. There's a reason why 99-04 V6s run mid-low 16s, compared to 5.0s which run mid-high 14s.Ever heard the terms "powerband" and "torque"?
Swarzkopf said:No, it doesn't get near the gas mileage of the 2.3. It's about the same as the 5.0. How do I know? I've owned all three. If you don't want a gas hog you want an economy car, not a performance car. If it's that big of an issue stick with a 2.3, turbo or otherwise. The V6 would be a mistake
Swarzkopf said:You do realize that a 3.8L is not that much lighter than a 5.0, right?
Swarzkopf said:Have you ever swapped an FI engine into a car where it wasn't stock before? It's not "easy" and if I were to do it, I'd want some kind of reward.
Swarzkopf said:You could probably do a 2.3T/5speed for the same price, it'd be ALOT easy, and you'd have a better runner...
More like 205hp. The 225 estimate was over rated. read under 1993.
Did you also account for the ~310lb weight difference between a fox and a sn95 car?
And yea I know the 5.0 makes more torque, but I'm not planning on drag racing this car
weight also plays a factor here. 5.0 got ~19mpg, 3.8 ~23mpg, 2.3 ~24mpg (note these are averages from what I have read). In reality they are close.
Probably, but I dont like turbos. If I did I still would use a 3.8SC engine rather then a 2.3T!
Red_LX said:Anyway...if you like the 3.8 so much, why aren't you over on the V6 forums?![]()
Sucellos said:After posting this, I will be moving on elsewhere. I asked this here because the car it is going into is a 1991 lx fox hatch with a 2.3l t5. I figured seeing as how this is the forum for these cars it would be a good place to start, guess not as everyone wants to holler 2.3t and give no thought to anything else. Needless to say yea I am going to use a V6 if for nothing else except to be different.
I always thought the 3.8 was a head-crackin, head gasket poppin' POS Thunderbird motor. I've walked away from very clean T-Birds simply because they had the 3.8 in them.
If you're gonna go V6, go BIG. Grab a 4.0 SOHC from an Exploder or new Stang.
I'm knockin down 27-30mpg on a regular basis in mixed driving.
