93 LX 5.0 question
Turkey Sammich
I can't fap normal. I cracked a rib, then my ankle
Jul 12, 2006
154
I recently bought a 93 LX 5.0. It has the HO motor in it. I've recieved mixed information about this car. ( As I know little to nothing about cars, sorry to say ). I've always loved the fox mustangs since I saw them.
Anyhow, my question is... What do you believe that I should add to improve performance? I wanted to start with simple low budget projects and work my way up. ( As I'm working 3 jobs and waiting on a possible oversea's deployment ).
This has what has been done to it, so far.
- 3.55 gears, E303 cam, subframe connectors, offroad H pipe, Flowmaster exhaust, fuel pressure regulator, k&n filter, short shifter, and it's been lowed two inches.
The problem with these cars is you dont gain anything from low budget stuff like other cars, the power is in cylinder heads, which run 800-1,500$++. This usually turns into a really long post about how you cant just bolt stuff on and make power, so Im just going to make it short, learn about cars, then figure out what you should do, all the low budget stuff has already been done on the car.
See the "Useful Technical Thread Index" sticky at the top of the 5.0 Tech forum. There is all kinds of useful information, including budget junkyard upgrades.
as stated above, the cheap quick stuff has been done.
Heads and an Intake Manifold would make the car a real animal....but do that and now you need new injectors, TB, MAF, and some upgrades to your fuel system to use the full potential of your set up, and to make it safe.
Here is what you should really do.....if you want to know more about these cars start reading the tech section, pay attention to peoples combos usually stated in there signatures.....ask good questions once you have gained some knowledge and you will begin to learn what is needed to make a quick car a fast car.
If it was me i would go like this.............
Aluminum drive shaft
Headers
Remove AC and Smog equipment
Electric fans
a simple tune up ( cap and rotor, plugs and wires....I like the ford 9mm)
Intake manifold
Thumper heads.......Do a search for them on this forum or check out his site
http://www.hunterstyle.com/thumper/
Dont forget the brakes suck on these cars so i would budget in some $$$ for brake upgrades maybe even a 5 lug conversion with newer componants.
Hope this helps you a little
:Word:
A big thank you goes out to all the feedback I've recieved.
I'm planning on going with a BBK cold air intake, and then the heads and continue from there.
Just for your info.
Im running heads/cam/intake with a stock throttle body, stock injectors, stock ignition, stock mass air flow sensor and MAF tube, and the stock rubber intake tube, i have no problems with any sort of choking or lean conditions. Once again, your just wasting your money right now with stuff like a cold air intake.
Do an intake manifold at the same time or you will be sorely disappointed with the heads. The stock intake manifold is the bottleneck on the motor.
This is the direction I'm intending on going.
Aftermarket Ignition System (ACCEL)
BBK 70mm throttle body
EGR Plate
Larger Intake Tube 76mm
BBK Shorty Headers
Hi-Flow Catalitic Converters
MSD Digital 6 Ignition
Underdrive pulleys
Edelbrock Performer Manifold
Edelbrock Heads
:SNSign:
EGR Plate
BBK Shorty Headers
Underdrive pulleys
Edelbrock Heads
:SNSign:
IMO , If you're going to drive the car daily,underdrives pulleys are not worth the money. Anything that makes the waterpump turn slower to make power(which makes the engine temp rise, which causes loss in power?)Doesnt make sense maybe they show gains ona Dyno pull or two, but I just cant see doin em on a car that is on the street all the time.Also notice nobody suggested em in their lists.
You wanna do it right the first time. Most bolt ons add very little power,(except for heads,cam,intake) and dont always work well with each other Save your money, Set a hp goal or e.t. goal if your goin to the track regularly, And find the combo that will meet that goal all at once. If you start buyin things one at a time, your gonna end up with a bunch of parts that dont work well together.Find a local engine builder you can trust,and start askin questions. Youll Kick your self spendin a hundred here , two hundred there and in the end, and then every time you change one thing, you have to change something else to make it work. IN the end you'll be spending more time and money than the guy in the lane next to you who had a combo built with kickin your ass in mind.
bryce93lx said:
Hey man that car is very clean congrats on the find, hey what part of Oregon are you from, i am from bandon on the coast, and i also sport a 93' lx
Yeah, found her on craigslist. Who would of thought. The prior owner was selling it due to speeding tickets :nono:
I'm from Hillsboro, 20 west of Portland.
