  • 2.3L (N/A & Turbo) Tech
93 lx won't start
  • Thread starter Thread starter djwkjp
  • Start date Start date Jun 1, 2006
D
djwkjp
  • Jun 1, 2006
hi guys--
first post here. so i went out yesterday morning to go to work and my 93 lx wouldn't start. it turns over but it won't start. so i called my buddy who is a mechanic and we did some troubleshooting. the fuel pump primes, the car is getting spark and fuel. we finally narrowed it down to a stuck injector that was dumping fuel into the third cylinder and causing it to flood. we changed the injector and tried it again and no luck. we are at a loss as to what it can be. my friend is upset cuz he has yet to work on a car that has left him stumped. what do you guys think it is?? any input is appreciated.
dan
Keasbey
915
Montreal
Jun 2, 2006
  • Jun 2, 2006
have you checked for codes?
88stangmangt
2,332
Stafford,VA
Jun 2, 2006
  • Jun 2, 2006
did you check fuel pressure?? did you take the dizzy cap off to make sure it is rotateing??
R
RustBucket
585
Buford, GA
Jun 2, 2006
  • Jun 2, 2006
93 won't have a distributor or a cap.
Pop the plug out of the front of the timing cover (or just look behind it at the cam sprocket) and verify that the timing belt is turning.
Swarzkopf
973
Pittsburgh
Jun 2, 2006
  • Jun 2, 2006
x2
Most likely this is your problem if you have both spark and fuel- the timing belt either snapped or has teeth worn off of it.
D
djwkjp
  • Jun 3, 2006
haven't checked for codes yet. the timing belt turns and appears to be intact. oddly enough, i went out last nite after i posted and it started up after a few seconds but ran really roughly. i drove it around for about five minutes and it ran rough the whole time. i havent had a chance to try it again, though. i think maybe it was still flooded after we replaced everything and trying it again just flooded it more. it sat for a couple hours before i finally got it started. i will try it again in the morning and see what happens. we are pretty sure it is getting adequate fuel pressure, but my friend's pressure gage appears to be faulty, the attachment for use on fords is really funky. it was reading pressure for a little bit but then it stopped. he had never used it before and he kind of cheaped out when he bought it. i'll let you guys know what i find out in the morning
dan
  • brandyn200
  • Jun 20, 2026
AeroCoupe
  • dan50
  • Jul 18, 2026
dan50
  • Locked
93 LX father son project
  • ZAM93LX
  • Oct 26, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 28, 2025
Progress Thread 93 LX father son project
  • ZAM93LX
  • Oct 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 3, 2025
Scrapla347
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
