  • 1994 - 1995 Specific Tech
94/95 Battery harness / cable
  • Thread starter Thread starter Skidude69
  • Start date Start date Aug 16, 2007
Skidude69
20
Kansas City, MO
Aug 16, 2007
  • Aug 16, 2007
I have searched and can’t seem to find a full replacement battery harness or even the total length of both sides of the battery harness. Does anyone know what length the positive and negative battery cable / harness is?
Thanks,
Jake
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Aug 16, 2007
  • Aug 16, 2007
Thanks,
Jake
I would just buy some 4ga cable and ends and make your own. Just take a look at where the cables go and make a guess and buy some extra just in case.
Scott
HISSIN50
34
129
Aug 16, 2007
  • Aug 16, 2007
LRS sells new cables - at the tune of over 200 beans.
Scott has the right idea. I might even suggest using 2 AWG. The only mildly tricky part will be cutting the terminal off the starter cable (at the battery cable connection point) and melding that to your new terminal. The issue is that you dont have much slack in the starter cable. If running a new starter cable, this is not an issue. But if you only really want to replace the battery cables themselves, it could be an issue to do decently.
Good luck.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Aug 17, 2007
  • Aug 17, 2007
are the factory cables 2awg? I had thought they were 4. But it never hurts to go bigger!!!!
HISSIN50
34
129
Aug 17, 2007
  • Aug 17, 2007
I believe you're right about it being 4 AWG Scott. I suggested the 2 AWG for just the reason you said - upgrade for the sake of upgrading. It's nice to have a little bit of fudge factor or accomodate larger alternators, etc.
Skidude69
20
Kansas City, MO
Aug 30, 2007
  • Aug 30, 2007
If anyone wants the info, the factory wires both are about 57". I used 2 gauge wire for both sides and all the way to the starter. I added an extra frame ground on the pass side motor mount to the sway bar mount. I also relocated the main ground from the water pump to the motor mount and to the swaybar bracket, much better connection!
Thanks!
Jake
HISSIN50
34
129
Aug 30, 2007
  • Aug 30, 2007
Thanks for the info Jake. It sounds like you did a nice job!
donkey_punch
565
northern****ingjersey
Aug 30, 2007
  • Aug 30, 2007
yeah sounds real nice, and i think it's in the near future for my stang.
got any pics?
Resolved 83 alternator wiring harness
  • sparten5000
  • Aug 2, 2026
Fox 5.0 Mustang Tech Aug 23, 2026
limp
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
T
2001 GT 4.6 V8 weak crank no start.
  • The-Bamboo-Farmer
  • Nov 12, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 13, 2025
The-Bamboo-Farmer
T
D
Electrical Need some Altenator wiring help please.
  • DanB93
  • Feb 3, 2025
Fox 5.0 Mustang Tech Apr 7, 2025
Rcdgl
R
