Here's what I got:
1994 Mustang GT, 5.0 w/AOD (E?) and 2.73 gears out back.
The tranny acts perfect at all times, except when you get on it.
If you floor it, when it comes time to shift, it doesn't. The stupid
thing will run up to the redline and bounce on the rev limiter all
day long rather than upshift.
If you take your foot off the floor, for a split second, and jam it back,
it will shift finally. Makes for a very rough upshift though. It also
is very late to upshift when you drive more aggressive than grandma...
Anything more than putting around town, and the rpms go higher
than they should before upshift. Full throttle has no upshift.
What is the problem?
TV cable adjustment?
TPS?
TPS?
You could just have the catted parts of your stock H-pipe replaced with straight pipe if you want to save some money. Then gut the cats that you've removed and recycle the insides as kitty litter.
