94 gt project
  • Thread starter Thread starter YEAHLOH95
  • Start date Start date Dec 10, 2011
YEAHLOH95
1,249
EVERETT,PA
Dec 10, 2011
  • Dec 10, 2011
i have my buddys 94 in my garage doing a cam and intake swap. its a dss 331 with patriot heads , it had a trick flow street heat and a crane power max 2020 cam i am in the process of putting in a anderson n51hr and a holley system max . the car dynoed 288hp and 380 tq last time on a mustang dyno . what do you guys think it will make with these changes ? i'll post up some pics soon as i get them off my phone.
Rick 91GT
Mustang Master
95
99
PA
Dec 10, 2011
  • Dec 10, 2011
Troy, Whats the compression ratio?
YEAHLOH95
1,249
EVERETT,PA
Dec 10, 2011
  • Dec 10, 2011
it has flat tops rick , with inline valve reliefs , i'm not sure of the dynamic compression ? with the small crane cam the car was done at 5k
Rick 91GT
Mustang Master
95
99
PA
Dec 10, 2011
  • Dec 10, 2011
with a 4cc flat top it would be in the 10.5:1 or higher range with a 58cc head. My last 333 with a Cobra intake made 380/404 to the tire on a MD done at 5400rpm...
Those numbers still seem low but Id guess youll pick up an honest 40hp, and loose a little tq...but it should carry power atleast another 800-1000rpm. Whats the basic .050" on that cam? I had a N61 in the past personally .544/,.568 228/232 110 if I remember correctly, My lil 302 made 340rwhp/tq on a Dynojet...made power up till 6300.
Make sure you have enough spring pressure....
YEAHLOH95
1,249
EVERETT,PA
Dec 10, 2011
  • Dec 10, 2011
its 226 234 @.050 520 528 lift ,the springs were only good to 550 that why i chose this cam , and when i pulled the lower off the gaskets were mis aligned by an 1/8 inch covering the port so that didnt help anything either .
YEAHLOH95
1,249
EVERETT,PA
Dec 11, 2011
  • Dec 11, 2011
new cam is in and i just need to adjust the rockers i hope to have that all done soon
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Dec 12, 2011
  • Dec 12, 2011
It's the heads. Also explains the high torque number. It's real hard to make power with Patriot heads.
Kurt
BlackVert
5,589
9
98
Bethesda, MD
Dec 12, 2011
  • Dec 12, 2011
Kurt
This is exactly what I was going to say. Those heads will hold it back pretty hard.
Rick 91GT
Mustang Master
95
99
PA
Dec 12, 2011
  • Dec 12, 2011
I replaced a set of Pro Comp 210's with a AFR205 and picked up 67RWHP once....no other changes
YEAHLOH95
1,249
EVERETT,PA
Dec 13, 2011
#10
  • Dec 13, 2011
  • #10
you guys are correct but i couldnt talk the owner into a better set of heads he spent all his money on the short block and getting it installed .now i am trying to make it run like it should or at least better
4Jenna
4,326
AZ
Dec 15, 2011
#11
  • Dec 15, 2011
  • #11
Thats nuts Rick!
YEAHLOH95
1,249
EVERETT,PA
Dec 16, 2011
#12
  • Dec 16, 2011
  • #12
well paul stopped by last night and helped adjust the valves and i'm headed out to garage now to put intake on and add fluids, i hope to have it running later today
4Jenna
4,326
AZ
Dec 16, 2011
#13
  • Dec 16, 2011
  • #13
YEAHLOH95
1,249
EVERETT,PA
Dec 16, 2011
#14
  • Dec 16, 2011
  • #14
another update i came in to warm up intakes on valve covers and dist. now onto cooling system and upper intake
YEAHLOH95
1,249
EVERETT,PA
Dec 16, 2011
#15
  • Dec 16, 2011
  • #15
all done car is running pulls hard but with cold roads and tires its hard to tell how good ifeels alot better than before
C
Dyno day! # guesses?
  • clayton seiders
  • Aug 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 16, 2025
Scrapla347
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
Fox 329 HP low for a stroker?
  • Andresquintana.mma
  • Apr 15, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 19, 2025
Jarhead67
J
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
