94 gt project
YEAHLOH95
1,249
EVERETT,PA
i have my buddys 94 in my garage doing a cam and intake swap. its a dss 331 with patriot heads , it had a trick flow street heat and a crane power max 2020 cam :( i am in the process of putting in a anderson n51hr and a holley system max . the car dynoed 288hp and 380 tq last time on a mustang dyno . what do you guys think it will make with these changes ? i'll post up some pics soon as i get them off my phone.
with a 4cc flat top it would be in the 10.5:1 or higher range with a 58cc head. My last 333 with a Cobra intake made 380/404 to the tire on a MD done at 5400rpm...
Those numbers still seem low but Id guess youll pick up an honest 40hp, and loose a little tq...but it should carry power atleast another 800-1000rpm. Whats the basic .050" on that cam? I had a N61 in the past personally .544/,.568 228/232 110 if I remember correctly, My lil 302 made 340rwhp/tq on a Dynojet...made power up till 6300.
Make sure you have enough spring pressure....
its 226 234 @.050 520 528 lift ,the springs were only good to 550 that why i chose this cam , and when i pulled the lower off the gaskets were mis aligned by an 1/8 inch covering the port so that didnt help anything either .
you guys are correct but i couldnt talk the owner into a better set of heads he spent all his money on the short block and getting it installed .now i am trying to make it run like it should or at least better
