  • 1994 - 1995 Specific Tech
95 GT DIY Clutch Replacement Tip
  • Thread starter Thread starter 95LRGT
  • Start date Start date Sep 26, 2007
9
95LRGT
12
  • Sep 26, 2007
Hi Guys, this is my first post here. I am on my 3rd Mustang, just bought this one last week, and I would like to change out the clutch and flywheel. Has anyone here done this as a 1 man job, and if so, what did you use to lower the transmission and more importantly, how did you align the shaft back through the flywheel and to the crank.
Any help would be appreciated.
Car info:
95 Laser Red 5.0/122k miles/5 speed/completely stock (yes,even the mufflers, and the silencer is still on)
94-302-vert
1,947
NE CT
Sep 26, 2007
  • Sep 26, 2007
One man can strongarm the T5 if you need to... but it is MUCH easier with 2 guys... Even if it is jsut one person to push the clutch in for you when you are 90% re-inserting the trans to get that last 1/4" of insertion. I have had to do this a couple times.... Heck my Wife ould have been a huge help so it doesn't need to me a mechanical person to help you out...
Good luck and welcome man...
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Sep 26, 2007
  • Sep 26, 2007
Look in the "How to" thread up top they have a write up in there.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Sep 26, 2007
  • Sep 26, 2007
You could use another jack to help you support the transmission up to the flywheel area...
You can align the shaft by twisting the transmission yoke a little each way until it slides or pops in.
whtstang pointed you in a good direction...check it out.
Good Luck!
Stanger007
2,015
Baton Rouge, LA
Sep 26, 2007
  • Sep 26, 2007
94-302-vert said:
...to get that last 1/4" of insertion. I have had to do this a couple times.... Heck my Wife ould have been a huge help so it doesn't need to me a mechanical person to help you out...
Perhaps a floor jack under the tranny may help maneuver it around.
Wes
HISSIN50
34
129
Sep 26, 2007
  • Sep 26, 2007
I hate it when you need someone to help get that last 1/4" of insertion.
94gsl5.0
223
seatown
Sep 26, 2007
  • Sep 26, 2007
I have also found it beneficial to have someone engaging the clutch to get that last 1/4 in.
Methodical
1,192
11
59
Clinton, MD
Sep 26, 2007
  • Sep 26, 2007
I've removed the transmission in my car about 4 times by myself. I used a hydraulic jack to lower and install the transmission.
To the get the trans shaft back in - all the way in - first use the alignment tool to get the pressure plate as straight as possible, then install the clutch cable to the fork, adjust, and after you've push the transmission in as far as it will go - with the help of the jack - have someone depress the clutch pedal and the shaft will seat for you. Easy as pie
Oh, check or better yet replace the rear main seal and the pilot bearing while in there.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Sep 26, 2007
  • Sep 26, 2007
If your rear main seal is in good shape or just a very small leak, I would suggest just leaving it. Often replacing the original gasket can make the issue worse...
Good Luck!
Methodical
1,192
11
59
Clinton, MD
Sep 27, 2007
#10
  • Sep 27, 2007
  • #10
Good Luck!
True that
9
95LRGT
12
#11
  • Oct 2, 2007
  • #11
Thanks for the tips, I'll get to work on drawing up some sort of lifting device to make the job a little easier.
I just changed out my power steering pump so if anyone needs tips, let me know
94-302-vert
1,947
NE CT
Oct 2, 2007
#12
  • Oct 2, 2007
  • #12
:Word: about the rear main seal... Should have listened and left the factory one in the car...
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
R
1994 GT 5.0L crank no start
  • Red1994MustangGT
  • Apr 15, 2025
2K
1994 - 1995 Specific Tech Aug 19, 2025
Kurt_MO
K
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
New Member with a 1992
  • Clutchfork
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 19, 2025
Clutchfork
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
