95 GT general performance question
Mikevr007
My brother has modified the car over the years with;
-slight exaust mods (new x pipe & flowmasters)
-new intake manifold & 65mm TB
-some brand of intake tube & K&N filter
-3.55 gears.
As far as I know, that's it.
At what point will the ECU not be able to "keep up" with modifications?
At what point should the injectors be replaced with higher rate injectors?
I've searched and read quite a bit, but haven't found anything I can decipher to more simpler terms.
Thanks.
Mike
-3.55 gears.
Thanks.
Mike
Those are all good mods. I think his computer will still be fine with these mods. Usually when there is a Cam put in is when the computer needs help.
As for injectors he should be fine until he puts a cam and heads on it. Then he will need to up the injectors and get an ECU tune.
