  • SN95 4.6L Mustang Tech
98 GT shift handle
  • Thread starter Thread starter tandbond
  • Start date Start date Apr 5, 2005
T
tandbond
  • Apr 5, 2005
Having shift problems with my automatic GT. I replaced the BOO switch and it didn't correct the shifter being stuck in park. I seem to have to push the stick all the way forward and squeeze the button very hard in order to get it to release and even then it sometimes doesn't work. Any ideas would be greatly appreciated....
nyuk98gt
1,427
Chesterfield, MO
Apr 5, 2005
  • Apr 5, 2005
tandbond:
The shifter may need a little adjustment. Under the car, you will find a linkage. The retaining bolt can be loosened so that the shifter can be moved forward or backward until it is "just right". This adjusting is best done with a buddy or you will make a lot of trips under the car.
edit: You're looking for the manual lever position sensor (MLPS). It connects the lever to the trans and there is a small electrical connector on one side. The older T-Birds had frequent problems with the MLPS.
end of edit!
HTH,
Chris
T
tandbond
  • Apr 6, 2005
Hey, thanks for the info! I will try and get to it today!
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
2008 Mustang Bullitt stuck in Fifth gear
  • Jester67
  • Jul 15, 2025
2005 - 2014 S-197 Mustang -General/Talk- May 27, 2026
Jester67
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
A
95 GT parking brake instrument cluster light trouble
  • Aroenias
  • Jun 23, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 24, 2025
Mustang5L5
