99-04 LT Header Installation
Burtonsnow157
51
I'm thinking about trying to install LT headers on my 03 GT, but dont even know if its possible. I have experience with mid-pipe and catback work and know the basics of installing a set of headers, but is it way too hard to make it worth doing in the drive-way?
I know at one point, you have you jack the passenger side of the engine about 4 inches. . . is that hard or does it just sound like that?
is this a d.i.y or pay like $500 for a shop to do it?
damn man that is involved. definitely seems like an 8 hour job. I have experience with the suspension and all that. . . the only things i haven't had experience with in the walk-through is removing the k member/motor mounts and the g-load brace. . .
overall, the job seems long but it looks like it just takes patience and time. i'm wrong about 500 dollars btw. . . guessing that it takes a shop at least 6 hrs to do, and assuming they charge around 120/hr (which they do around here) that would be 750 at least, but probably more like 800-900 dollars plus headers. . . annnnnd the midpipe lol
shop: $1700 me: $900 i dunno might be worth the hassle
Dude I did them at a friends house over a 2 day period (16hrs total) and I would rather pay $1000 than do that again. We did it with out dropping the K-member which alot of people drop it. The passenger side is the hardest part. There is like no room to fit a wrech and you're doing it all blind just by feel.
I installed mine in about 11 hours, took me probably 2 hours just to do one sid. I dropped thew wholeK member, and eveything, it doesmake thingsmuch easier. The hardest part, is getting to the bolts that hold the headers on, And tightening them down. But if your like me, and can save some money, do it yourself. Plus you have the satisfaction of telling other people you do your own work! BTW, I did mine starting about about 7 at night and I didn't finish until about 6-6:30 in the morning. being on my back that long gave me a new appreciation for a working girl! LOL :nice:
11 hours is a long time but it honestly doesnt sound that bad. as long as everything went correctly it would be cool. if it took eleven hours but everything happened like it was supposed to smoothly i'm fine with that. i could have the car up and drop the k member in under an hour probably
my powertrain warranty isnt up until 10/2009 though so i dont know what i should do about that. if something happened between the header install and then i might have trouble getting warranty work done.
I would just tell you to remeber Murphy's law, you probably will have a hiccup here and there, but it's really not that bad. Myabe alittle exhausting, but I'm sure you can handle that. As for the warrenty, call and ask if it will void it, I doubt headers woudl effect it, but you never know.
Yeah good luck and hope it works out for you...BTW what headers did you/ are going to get??? I got my Mac longtubes and a prochamber midpipe for a rediculous price off of craigslist. Only 125.00 for both, still in the box. The guy bought a 95' saleen, and couldn't use them anymore. The yhad been sitting around his house or like two-three years, and I saw his add. I alomst thought it was a scam and I was going to get kidnapped when I went to pick them up.:OT:
I've had my headers on/off at least 4 times now.. Dropping the K member is the ONLY way I would recommend doing it.. It's just so much easier with the K off since you then have a straight shot to almost all of the bolts. This will also let you install them properly by torquing them to 20 - 24 ft/lbs.
I would also recommend a good set of ratcheting wrenches and I like to use the Stage 8 locking header bolts. That way you KNOW nothing will leak and you won't have to tear into it again. I use the stock ford gaskets.
While you're in there it's also a good time to do a solid steering shaft, motor mounts, upgrade your ground wires, etc. Might as well do it all at once..
Riley
I say DIY also. I basically had no experience working on cars before I got my 98. I was able to drop the K and put shorties on in a weekend. As long as you research and are confident in your wrenching, its a great experience to do your own work. It somehow reinforces that car nut in us all.
i'll have to take a look on craigslist, there was an ad for bbk lt's and midpipe for 550 brand new. If i get new from a store i was gunna get the Pypes 304 s/s lt's for $399 and then a catted mid for around 300 probably bbk.
with lt's and a catted mid i should be able to pass emissions right?
when you say that do you mean that i should just put them on and if i run into engine problems/warranty work just take them off?
My warranty is long gone since the car is a 2002.
I was just saying that I've done it multiple times and ways and dropping the K member is the best way to do it..
I've found that dealers vary wildly and your best bet is to ask. I had a dealer void the warranty on my axle seals because I had FRPP springs installed. Then they said that the seals weren't covered under the powertrain warranty. I even brought them the book where it said they were covered and they refused to do the work.
Your best bet would be to ask.
Riley
I used that same link to do my lt header install. I suggest getting a wratcheting, swivel head, 13mm wrench. Makes those header bolts easy to get to. Also when you drop the k member you can lower your engine about 4 inches or so to get some extra room to work with. The only thing I had trouble with was getting the EGR tube off. I ended up breaking it so I just blocked it off and turned it off in my tune. I just took my time and did it over a weekend in my garage.
I am thinking of taking mine off my 96 Cobra. I have a hoist at work, a forklift, and plenty of floor jacks....BUT...I want to support my engine from the top. How are you guys supporting them from the top?? What bolts do you take out?? I just want to chain it to the forklifts forks and do it that way.
installing lt's are not all that hard today just alittle work and if your like me you will be happy that you did it your self good learning exp.
i dropped the k-member makes life a lot easier when installing the heads
toke me a weekend but i did the install by my self get a friend if you can can be done in a day
disconncet the battery
jack the car up with jack stands support
remove wheels /brakes/struts/springs
disconncet from the drive shaft
unbolt motor mounts
support motor with jack
unbolt k-member
remove old heads
install new lt headers
and reinstall everything else
sounds more complexs then it is
dont be shy get to know your ride :D
ps i did this install in a parking lot (murder on your back laying on concret for hrs.)
You people are crazy, I put my long tubes on, by myself in 6 hrs without dropping the k-member. It is tight, you will get mad, but if you have patience and a good set of tools you can do it. I always here people talk about dropping the k, but I will never do it like that. To much work. I just put the motor back in my car and before I bolted the motor mounts on I hung the motor by a engine hoist and bolted the tranny and then put the headers on. I was able to move the motor a little bit, enought to be able to get all the bolts in and get a rachet wrench on almost all the bolts, some I had to use a reg. wrench. A couple I used a socket and ext. It worked for me and in about 6 hours all my exhaust work was done and I moved on to finishing the rest. Took me about 15 hours soild, to put the motor in, all the exhaust hookup, and all the other BS. But it ran that night and the next day I got to drive. Good luck on the install.
