  • SN95 4.6L Mustang Tech
A bump in the frame?
  • Thread starter Thread starter GTtopLESS
  • Start date Start date Nov 14, 2007
G
GTtopLESS
79
  • Nov 14, 2007
My first post! Just got a 02 vert with 60k. Car feels super strong but have no idea what was done to it. I got a speed cal (gears but no idea what kind); x pipe with cats (no idea what type); steeda shifter; def lowered (not sure how much or brand) . Couple questions for you all. Any idea how I could find out what kind of gears are in the back? What kinda springs? AHH and my only critical question is that occasionally I feel a "bump" in the chassis (under my ass) when puttting into gear, could this be a tranny/motor mount? Thanks everyone, I've already learned a crap ton of info from reading your posts.
A
avexhype
14
  • Nov 14, 2007
i too have the bump or clunky 'thud' when shifting into 1st from a dead stop.
2002VertGT
15
Madison, WI
Nov 14, 2007
  • Nov 14, 2007
I think you can check on the inside of the door to see what gears you have. Also isn't there a tag on the pumpkin in the rear?
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Nov 14, 2007
  • Nov 14, 2007
The tag on the rear will only tell you the gear that came from the factory. If they are changed...this won't help you. The bump could be a bad trans mount. Those little ones which are on the 01+ cars always go bad. Bad design.
G
GTtopLESS
79
  • Nov 15, 2007
there is no way to tell what kind of aftermarket gears are in there? ok thanks, time to check tranny mounts. gracias
2002VertGT
15
Madison, WI
Nov 15, 2007
  • Nov 15, 2007
Not sure about this, but I think you can put the rear end up on jacks, turn the driveshaft and see how many revolutions the wheels turn, that should give you the axle ratio right?
You could use one of those online calculators that calcs tire size, speed and rpm, but I guess you wouldn't know if the speedo gear has been changed.
Paint and Body Frame rail dimensions
  • keel
  • Jan 30, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 13, 2026
keel
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
F
Rear Drum Brakes
  • Fri Guy
  • Jan 3, 2025
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 8, 2025
Scrapla347
2001 roush stage 3 - sat for 5 years
  • Brando_05
  • Aug 26, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 26, 2025
Brando_05
