Electrical A/C added to deleted car questions....
ggradtech
179
18
28
My 93 (4 cylinder converted to 5.8) has no A/C. It did at one time, and the condenser fittings look like they were basically “capped off” at the firewall. I’m not sure about the “health” of the condenser, but would rather roll the dice and see if it’s ok to use 1st and only remove my dash if I need to. Would I need the electrical relay that controls the idle and bypasses the AC under WOT? I don’t have those electrical parts installed and don’t know if they are needed or not. Will the car idle work properly if I added A/C but didn’t install the relays/ WOT disable thingy? Thanks.
I would need to reference the wiring diagram but i do believe compressor power does route through the WOT relay. If that's the case, it needs to be added.
The wiring should be present in the harness if you are using an OEM harness. Are you? If so, it should be in the area of the pass side strut tower.
The following are diagrams courtesy of Tmoss & Stang&2birds
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
Engine mounted fuel injector harness
5.0 wiring diagram for Fuel Injectors, Sensors, and Actuators
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring; http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
TFI module wiring for 94-95 Mustang GT
http://www.veryuseful.com/mustang/tech/engine/images/Mustang-94-95-IgnitionControlModule.gif
Complete computer, actuator & sensor wiring diagram for 94-95 Mustangs
Complete computer, actuator & sensor wiring diagram for 88-90 Mass Air Mustangs
Main body EFI wiring harness
Ignition switch wiring
O2 sensor wiring harness
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pin out
Fuse box layout
Mustang 5.0 Lights and Radio schematic, by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/mustangFoxLights-Radio_diag.gif
87-92 power window wiring
93 power window wiring
T5 Cutaway showing T5 internal parts
Visual comparison of the Ford Fuel Injectors, picture by TMoss:
Convertible top motor wiring http://www.veryuseful.com/mustang/tech/engine/images/mustang88VertTopMotorCkt.gif
Location of the TPS, IAB, and the 10-pin connectors on a 5.0, picture by TMoss:
Starter circuit
Alternator diagram for 94-95 Mustangs.
