Quick question, I just bought a 94 GT off of a guy and he took the liberty of cutting the A/C evaporator lines at the firewall when he did his A/C removal and basically ****ed them up completely in doing so, because he didn't want to buy the A/C quick disconnect tool. Anyway, this means that I have to replace the A/C evaporator core to hook the A/C back up. This is essentially the same job as replacing the heater core correct? Only reason why I ask is because my Ford service manual of all things says that if the A/C evaporator core needs to be replaced, that a whole new housing (that holds the evap core, heater core, etc.) is required to be installed. Now that is just ridiculous, if I just follow the directions for replacing the heater core, I should have the access needed to get the A/C evaporator core out and install a fresh one correct? Just curious because my service manual mentioned the housing, which I don't see the point in having to replace the entire thing. Anyone ever do their evaporator core before?
Thanks guys!:SNSign:
... My first sn95, had 2 fox bodies previously... Black on black 94 GT
