I just got my heads back from the shop, GT-40P rebuilt with tougher valve springs. My questions revolve around the heads. Over the stock E7TE's, what kind of changes in the power band if any can I expect. Also, will the P heads raise the compression over stock? I found a summit rebuild kit for a 5.0L for $269 that includes .030 over pistons, gaskets, all the bearings, oil pump, its supposed to be a pretty complete kit of parts. Anybody used this kit? I am gonna try to find a junkyard GT40 intake off of an explorer to go with my motor but that might come later. Also, the guy that did my heads said the valve springs were rated for about .515 lift. What should I set the red line at for my motor. I will be using ARP Main, Rod, and head bolts. I just need to get an idea of the RPM range I need to make a choice on a cam.
Thanks,
Joey
Thanks,
Joey
