A little help needed
irish
168
Florida
Hey all, finally got my act together and finished off the engine/tranny re-install and got it running again, runs great/sounds great/looks great, must be a Mustang...anyway I'm now ready to put some decent rubber on it, it is an 88 GT with a full Saleen body kit and 16 inch Saleen rims with centercaps, currently the rear is 245/45/ZR16 and the front is 225/60/ZR16, should I replace these with same size or should I be changing to a different size?? Also, I have a bit of a lean in the left rear, distance from fenderwell center to ground is one inch taller on the passenger side than the drivers side with nobody in the car, probably is worse with my big butt in there, what can I do to fix this or what causes it? I do have subframes in the car...thanks and thanks for the help getting my car running good again!
I would guess that there could be a problem with your springs or shocks/struts. And about the tires.. If your not racing and just driving on the street I would probably run the same thing.. though I personally have 4 225's all around on my 88 gtc.
