? about 96 brake swap to a 91 Fox body, Help!
SVTFreak
106
Ok, i have all the parts. The axles from the 96 are longer. Im told that is normal, but will it change the offset needed for the wheels? How much? I used a 95 rear end in my cobra kit car and the offset i had on the stang worked right for the kit. It was designed to use a 87-93 rear, so im scratching my head after seeing the axles.
Main thing is, what do i need for an E Brake cable? Or how do i need to modify one to work?
Lastly, Will 15" prostars fit over the 95 front brakes and 96 rear disks? (3.5" fr and 8" rr)
I know SOMEONE has done this swap, so any help or advice is greatly appreciated.
Sorry, but im used to building cars from the ground up and fitment issues can be resolved with a flamin' hacksaw and a Mig :D Thanks in advance!
If you use the SN95 disk brake hardware from the rear with the '96 Axles, it will fit fine. It will push the rears out 0.75" each side
What brakes are you running?? GT brakes?
Those would be 10.8" front and 10.5" rear brakes. The 15" wheels should fit fine.
