Abpot to order 275/50/15 w/ 15x8 drags lies, will it fit?
About to order 275/50/15 w/ 15x8 drags lies, will it fit?
Im looking to make sure this will fit. Ive done searchs on it and pretty much feel they'll fit. For the rear I have pro3i control arms, lakewoods 50/50, and stock springs. Will they fit. Some say yes and some say know. What up?
Do a search on "backspacing" the tire will fit, the rim will need to have the correct backspacing. Call the folks you order the rims from and ask them what BS you need for your car. They will hook you up and take it back if they are wrong. Have you visited www.tirerack.com they have good tables on the site to help you make the right choice. if you are running the original quad shocks in the stock location they prolly wont clear. You will have to flip them to make room or eliminate them by other means.
thats the tire i run on my 86 fox i still have quad shock installed there is a little rubbing but not bad. i guess there would be no rubbing without quad. those quad shocks r just for wheel hop anyways. do some rear control arm work and you dont have to worry about that
if you haven't ordered the wheels yet, why not consider a larger rear wheel...15x9 or 15x9.5 might be better...maybe even 15x10. Putting that large of a tire on an 8" rim will give more bulge, which isn't necessarily good. There's been a lot of controversy about it, but i'm concerned about it so much, I'm probably gonna buy bigger wheels if I get 275's and get some 15x9.5's or maybe 15x10's...maybe throw the 15x8's up front w/ some 235's
It's your car and your decision, though.
