Stang and 2 birds: How many hours would you say you have in your abs install?
Hard to say. I have a unique install. I have my ABS unit where the coil used to be - on the driver's side inside fender. Also, I did my ABS install at the same time I did my M2300K kit. So, there was a lot of overlap. And, back then, you couldn't get ISO flare tools or ISO unions. And, it took my a
lot of time to make the custom brackets and fit the controller in that location.
So...
o Do you have to put rear ABS sensor rings on the rear axle? That could be take a long time because of the internal pin may break, the drain plug may not come off, etc.
o Similar with front bearings.
So... Let's
assume that "all" you have to do in put in the sensors, wires, control unit, and wires. I'll take a wild *ss guess and say 1-2 weekends (2-4 days). A
lot depends on where you put the controller and any brake line mods you make.
I just replaced ALL of the brake lines in my '93 Olds. And, I do mean
ALL! For me, time is valuable. So, I went and bought ~$200 of
coated ISO brakes lines of
various lengths and many unions. Also, since it's in my Olds, I cared more about the brake lines being functional and
safe, verses making them "look nice". I save a ton of time doing that way! I likely saved 8-20 hours of work. Plus, I only did 2 "test lines" to get the bends I wanted. Also, I bent about 90% of the lines by hand.
For my Stang, I used coper lines to get a prototype line with the bends and the correct length. And, all bends were done with a tubing bender.
Here's where my ABS controller is:
http://www.veryuseful.com/mustang/joe/brakes/graphics/absCtrView3.jpg
(Note: old picture, a few upgrades since then)
Here's a picture of my prototype copper line verses my brake line:
http://www.veryuseful.com/mustang/joe/brakes/page2/brakeLineProto.jpg
Wish I could be of more help. IMHO, trying to do it in one weekend may be possible. But, I wouldn't recommend it. You don't want to rush stuff like brakes. Also, don't forget the need to bleed the whole system when you're done.
Anyone else have a better idea of the time involved?
