  • 1994 - 1995 Specific Tech
AC Coil?
  • Thread starter Thread starter Navi Man
  • Start date Start date Oct 9, 2011
N
Navi Man
14
Northwest
Oct 9, 2011
  • Oct 9, 2011
My AC compressor froze up so I can no longer use my AC until replaced but for the time being it sounds like the AC clutch bearing is making noise. I have a used clutch that will fit on but when taking the old clutch off the replacement clutch won't fit over the coil as it was fried when the compressor froze and looks distorted. I currently have the wire disconnected from the accumulator so if the heater/ ac switch is turned on it won't activate the clutch (doing so locks up the clutch as the compressor won't turn) and allows the pulley to free spin. Could I just remove the AC coil and put the good AC clutch on with no coil as the old one is making a lot of bearing noise.
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,647
214
Acworth, GA
Oct 9, 2011
  • Oct 9, 2011
Yeah, you can do that. It is pressed onto two different parts of the compressor. Autozone rents a tool to pull that off.
Kurt
N
Navi Man
14
Northwest
Oct 9, 2011
  • Oct 9, 2011
Kurt
Thanks Kurt. I didn't think there would be an issue with it but just wanted to hear some opinions. It's going into winter soon here and likely won't tackle the ac compressor replacement till spring, plus it's a vert so always have instant ac available.
2001 v6 New compressor issue
  • badmech
  • Apr 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 30, 2026
badmech
F
AC Compressor Power & Contour Fans
  • Fri Guy
  • Aug 27, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 15, 2026
BoostedRed89gt
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
M
  • mnky99
  • Sep 5, 2025
mnky99
M
Gen 3 Coyote Swap Variable Displacement AC Compressor Troubleshooting
  • rydnoryder
  • Jun 12, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Jun 16, 2025
rydnoryder
