  • 1994 - 1995 Specific Tech
ac compressor removal.
  • Thread starter Thread starter EXTRPR50
  • Start date Start date Apr 20, 2006
EXTRPR50
370
  • Apr 20, 2006
I ve searched the archives, no luck. Im looking for anything more on the removal and install on the compressor, except for needing the quick disconnect tool. Or is it really that simple by removing a couple of bolts?
What about the lines going into the compressor?
mootang
907
texas
Apr 20, 2006
  • Apr 20, 2006
there is a bolt that holds that line on the compressor(I think) and there are 4 bolts holding the compressor on the bracket and the electrical plug. pretty easy to take off.
95strokerPSU
986
Sacramento from Philly
Apr 20, 2006
  • Apr 20, 2006
I removed my a/c completely and from what I remember it really was just that easy. Get the system drained and then get the quick disconnect tools. Are you trying to replace the compressor or remove your a/c? Which one is the compressor, the cylinder on the firewall or the thing in front of the radiator?
mootang
907
texas
Apr 20, 2006
  • Apr 20, 2006
the compressor is the one with the pulley on it!
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Apr 20, 2006
  • Apr 20, 2006
It's a simple procedure. There's a couple bolts holding it to the engine (not sure how many, but I changed mine last year), and one bolt that holds the block where the high and low pressure lines attach to the back of the compressor itself. If your AC system is already evacuated, it's a 25-30 minute job.
EXTRPR50
370
  • Apr 20, 2006
Hey, thanx for the help guys! Yeah, I just want to get the bad one off and get a used one from a yard. Are there seals or anything needed to put it back in? Like seals where the block goes? I have just heard about a.c. seals that go bad, and didnt know if I needed them. Thanx again
Methodical
1,192
11
59
Clinton, MD
Apr 22, 2006
  • Apr 22, 2006
There are seals on the end of the hard lines going into the A/C compressor but they should still be good, just inspect them. If bad if I remember correctly you can purchase from the dealership. Or do they make you buy the entire a/c line - just check with your dealer. But I think they will probably still be good. Just put some of the old R134a from the old compressor on the seals if not already on them - no oil or grease.
EXTRPR50
370
  • Apr 22, 2006
Thanx Methodical.
BlownFiveLiter
18
108
Chicagoland
Apr 23, 2006
  • Apr 23, 2006
Huh? R134a is gas when exposed to the atmosphere. Put some of the PAG oil on the o-rings when you refill your system and you should be all set.
2001 v6 New compressor issue
  • badmech
  • Apr 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 30, 2026
badmech
M
  • mnky99
  • Sep 5, 2025
mnky99
M
T
Losing Refrigerant rapidly on my 98 Mustang GT
  • TekoSn95
  • Jun 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 17, 2025
TekoSn95
T
VE Table Not Dialed? Send Me Your Datalog.
  • X-cam34
  • Feb 8, 2026
  • Digital Self-tuning Forum
  • 2 3
2K
Digital Self-tuning Forum May 1, 2026
X-cam34
W
Progress Thread 1984 2.3L Turbo AC Compressor
  • WAR2D2
  • May 2, 2025
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech May 2, 2025
WAR2D2
W
