accel problems
  • Thread starter Thread starter Cjfoxbody13
  • Start date Start date Jul 21, 2009
C
Cjfoxbody13
27
Saint Augustine, FL
Jul 21, 2009
  • Jul 21, 2009
I have a 91 LX 5.0 and it is completely bone stock. My father was the orig owner and I have had for a few months and drive it as my daily driver but, all of a sudden when i give it open throttle it hesitates after 4,000 rpm's. Like it is hidden the rev limiter. But not all the time... What should I change first? I was thinking spark plugs or fuel pump...
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 21, 2009
  • Jul 21, 2009
The TFI module mounted on the distributor is usually the culprit for a high speed miss on a warm engine. If the problem does not occur when the engine is cold, the TFI module is definitely suspect. You may need a special socket to remove the TFI module, but most auto parts stores will have one for $5-$7.
Be sure to use plenty of the heat sink grease on the new TFI and clean the old grease off the distributor.
See Automotive Tools Specialty | Auto Mechanic & Technician Diagnostic, Testing Equipment | Thexton
C
Cjfoxbody13
27
Saint Augustine, FL
Jul 21, 2009
  • Jul 21, 2009
Come to find out it was the alternator. The alternator and plug were shot. So I replace and so, so good... But thank for the info. Im going to go ahead and replace the TFI since its a cheap easy fix. I appreciate your help.
  • Mindseye007
  • Aug 16, 2026
Mindseye007
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
Electrical 92 Fox 5.0 no start
  • xwhiskeyechox
  • Apr 24, 2025
Fox 5.0 Mustang Tech Apr 25, 2025
AeroCoupe
