  • SN95 4.6L Mustang Tech
Accufab 70MM TB & Plenum
  • Thread starter Thread starter Rocketman
  • Start date Start date Jul 12, 2004
1 of 2 Next Last
R
Rocketman
730
SoCal
Jul 12, 2004
  • Jul 12, 2004
Installed the Accufab 70MM TB&Plenum combo this weekend. Good mod, highly recommend it. Noticeable difference at WOT and throttle response was improved. Put in a Hawker Odyssey PC680 battery at the same time.
01GT eibach
1,075
Pittsburgh, PA
Jul 12, 2004
  • Jul 12, 2004
Is there any SOTP gains less than 3000 rpm?
R
Rocketman
730
SoCal
Jul 12, 2004
  • Jul 12, 2004
Don't really notice anything under 3000 RPM. But, when I nail it the throttle response is very noticeable and at around 3500-4000 rpm, you can really feel it on the SOTP meter.
stang976
853
Westchester, NY
Jul 12, 2004
  • Jul 12, 2004
yea i canat wait to order the pair. if i can only find the combo for $400 shipped brand new
J
Jakes
84
  • Jul 12, 2004
I got mine from www.mustangtuning.com for $405 including shipping. I emailed them asking for a price quote, cheaper than the price given on the site.
I agree, much better throttle response but no real SOTP improvement below 3000 rpm. At WOT and over 3000 rpm it's a different story.
ToplessStang
591
Montreal, Canada
Jul 12, 2004
  • Jul 12, 2004
I have no mods at all, do you need a higher flow exhaust to feel the diffrence or will the Accufab alone make a diffrence?
propellerhead
1,541
"but what's with the but shots?"
Jul 12, 2004
  • Jul 12, 2004
Hmm... this fits right in with my full intake & exhaust upgrade path.
A
AmerMuscleGT
31
Connecticut
Jul 12, 2004
  • Jul 12, 2004
How easy was the install? Can I do it myself at home with a set of sockets?
R
Rocketman
730
SoCal
Jul 12, 2004
  • Jul 12, 2004
The guys over at MD did a big wright up on TB&Plenum combo's. I think the car they used was basically stock. Here's the tread.
http://forums.modulardepot.com/showthread.php?s=&threadid=20529
J
jsmaye
852
Amarillo Tx
Jul 12, 2004
#10
  • Jul 12, 2004
  • #10
Any low-end loss?
I've read years ago that you can lose low-end power when you go to a larger TB - the smaller diameter trades volume for velocity, which helps torque at < 3000 rpm. Did you notice any drop-off?
R
Rocketman
730
SoCal
Jul 12, 2004
#11
  • Jul 12, 2004
  • #11
I did it with a 8mm and 10mm socket. I did use a torque wrench to tighten the plenum bolts down. I didn't want to crack the plastic lower. The TPS screws are hard to get out with just a screw driver. I have a phillips head screw driver socket attachement for my 3/8 ratchet that worked great.
ToplessStang
591
Montreal, Canada
Jul 12, 2004
#12
  • Jul 12, 2004
  • #12
I read the plenum comparo and they used
"The test car is a 2003 Mustang GT and has BBK Long Tube Headers, BBK X Pipe, Magnaflow Catback, Steeda Pullies."
I was just wondering if it's worth getting more air in the engine if the stock exhaust can't let it out.
twogts4us
4,188
12
79
Dunedin, FL
Jul 12, 2004
#13
  • Jul 12, 2004
  • #13
I've got just a cat-back, and the SOTP blast at 3K RPMs + is awesome. The stock exhaust isn't that restrictive, but I'd honestly think about getting a catback (at least) before intake mods. Just my 2 cents...I agree with your thinking - what goes in must come out.
With a 70mm TB there is no loss at lower RPMs. Even with a 75, the dyno shows no loss on the test car at MD. But at the time, Accufab recommended a 70mm, so that's what I bought.
Here's mine - jeez, lookin a lot like Rocketman. Hey Rocketman, did you weigh the batteries? - that must of been quite a weight loss.
twogts4us
4,188
12
79
Dunedin, FL
Jul 12, 2004
#14
  • Jul 12, 2004
  • #14
Yep, it's a pretty easy swap - What I didn't have at the time was a DEEP 10mm socket for the rear EGR bolt.
And for the TPS, I took the old plenum and TB off as one piece, put it in my B&D Workmate, and used a power screwdriver and a little wrist action and the screw came out pretty easily.
You could really do this swap in 15 min, but we took our time, cleaning along the way and spent about 45 min. (It's a good time to clean all the crap off your manifold.)
R
Rocketman
730
SoCal
Jul 13, 2004
#15
  • Jul 13, 2004
  • #15
Did not weigh the PC680. Was going by the shipping weight on the receipt.
K
Ken01GTvert
175
Colorado
Jul 13, 2004
#16
  • Jul 13, 2004
  • #16
I ordered mine from rpmoutlet last week and it was $419 shipped. I currently have 70mm Accufab TB and C&L which I like but want to get the extra nice polish of the Accufab plenum and the slightly bigger TB.
K
Ken01GTvert
175
Colorado
Jul 13, 2004
#17
  • Jul 13, 2004
  • #17
I put PC680 in a couple of weeks ago. I weighed them before and found that stock battery was 35lbs and PC680 was only 15lbs. I got the best deal off of ebay. Also, I see that you have C&L inlet pipe and MAF. I used to have the same setup but after putting on the bigger TB and Plenum I started throwing codes (lean). I removed the C&L MAF and the codes cleared up. I was wondering if you ran into the same problem and if so how did you fix it?
R
Rocketman
730
SoCal
Jul 13, 2004
#18
  • Jul 13, 2004
  • #18
Actually I have the BBK CAI unit with my stock MAF meter bolted in. Never had a problem with codes.
ADRENLN
2,342
NJ
Jul 13, 2004
#19
  • Jul 13, 2004
  • #19
where did you get the battery from? will it hold a good charge being that small? does it have as much juice?
R
Rocketman
730
SoCal
Jul 13, 2004
#20
  • Jul 13, 2004
  • #20
Got it here.
http://www.batteriesplus.com
So far so good. Starts the car just like the stock battery, can't tell a difference.
1 of 2 Next Last
F
Trouble Shooting Sudden Shift of AFR at low RPM
  • Farva_84
  • Jun 6, 2025
SN95 4.6L Mustang Tech Jun 8, 2025
Farva_84
F
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
O
Need a hand: Hanging idle with all new parts
  • Overused03
  • May 15, 2024
SN95 4.6L Mustang Tech May 21, 2024
Overused03
O
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
Resolved Fixing a GT40P Valvetrain nightmare
  • foxbodyclark
  • May 21, 2025
Fox 5.0 Mustang Tech May 24, 2025
limp
