I just added a SS Bassini X to my 03 Gt. I'm really impressed with the performance, it seems to have really picked it up on the top end. The only thing I don't like about it is the raspiness. Yeah, I know I shouldn't have got a X pipe but I wanted it for the top end that I got. I'm not sure if its the raspiness or not, it sounds like air blowing out when you mash it hard and no rumble. I've done a search and found that the catted X is not as raspie. My X is a five peice does Bassani make a cat that I can add to it? If I do will it take my gain away? What about a catback? Right now I have the stock catback. Is there a catback I can add that will help with this without making the thing to loud? BTW, it sounds great at idle, low rpm's, and even when it winds out. Its only between 3 and 4k I get this "air blowing" sound. Is this normal.
Thanks
Thanks
just doesnt sound too good. Just get ahold of some off road pipes to put in there. As to that air issue, there is a good chance it can be a leak, have a friend cover the tailpipes while its running and have a listen and just feel around. If there is a leak, you will feel it under there. make sure to check the passenger side connection to the exhaust manifold. did you put in a new gasket? mine was leaking there when i first put in my x.
