additional parts for TorkTech m112 kit.
spopa
12
Skokie, IL
Hello,
Apart from the TorkTech kit, what else is needed to complete the setup?
Will the cooling lines connect to the engine cooling system (same radiator for everything)? or a separate radiator for intercooler is needed?
If someone did this, please "chime in" of what is exactly needed.
Is the intercooler from TorchTech exactly as the one on a stock Cobra?
is there another adapter variant for the m112?
thank you
As I understand it, the upper coolant line is just a trimmed down version of the stock one. There is no change to the lower coolant line.
The intercooler in the lower intake is similar to the 03/04 Cobra, but not exactly the same. It does have a separate radiator (usually just called a heat exchanger), which is not part of the kit, but any 03/04 Cobra heat exchanger can fit.
These kits use any supercharger designed for the 03-04 Cobra, which I believe there is an adapter for the GT500 M122. It will not use a Lightning M112.
The Torktech site covers the specifics of what is/isn't included in the kit: http://www.torktech.com/faq-1.html
