Adjustable FPR Unnecessary???
JasinC19
What hole is this!?!
Jun 7, 2011
312
Well the first startup of my build is getting closer, so I was reading up on what I should set my fuel pressure to initially for my mods:
TFS Top End Kit, 255 fuel pump, 75mm throttle body, 24# injectors, and a calibrated MAF.
Everyone is saying to set it for stock 39psi! So why are these things even necessary?
Other than looking freakin sweet
It'll help you to get things running up and smoothly-idle mixture sometimes plagues people running aftermarket meters and bigger injectors...then when you tune it, you set it back to factory pressure.
Sent from my iPhone using Tapatalk
The only place the adj fuel pressure reg will give you more fuel is at WOT when the vac drops out. Otherwise the stock EEC will modify the injector pulse width based on the feedback from the O2 and various sensors to get the A/F in check. If you need a little extra fuel up top, that is where they help but with a tune/chip they will add fuel through the program.
Set it to 36-38psi vac off...you'll be fine.
