Advice on engine parts.
  • Thread starter Thread starter wickdgt
  • Start date Start date Jun 27, 2007
W
wickdgt
15
Flint, MI
Jun 27, 2007
  • Jun 27, 2007
Currently I'm building a DSS 331 short block. Here is what I have could you please give me some advice to get the most out of it. Its going into a 87GT thats currently speed density, but want to upgrade that to mass air while builing the engine.
DSS 331 Short Block
FRPP X303 Cam
AFR 185 with spring and rocker stud upgrade
DSS racing 1.6 RR
FRPP 30# injectors
Kirban FPR
High Flow Fuel rails
190lph fuel pump
TCI Rattler damper
Meldon High flow water pump
I have a new Cobra intake but I know its not up to the job and anything else that would help. I'm also planing on getting the DSS racing 7qt oil pan and high flow oil pump.
A bit of help on the drive line would be great too. Here is what I currently have.
TKO 600 non RR
FRPP aluminum drive shaft
I'm looking on advice for a new clutch (currently king cobra but I know it will need more). It still has the stock rear end and not sure if I should go with the 3.73 or 4.10. It will be used mostly on the street with some track use.
I have already upgraded the brake system to the 5 lug Baer tracker 13" front and 12" in the rear. 10 way adjustable shocks and struts with lowering springs for a nice tight ride and Baer's bump steer kit.
Please help in anyway. Thank you
351vic
33
Pierz, MN
Jun 27, 2007
  • Jun 27, 2007
I'm not very familiar with the fuelie business but as far as your internals go, the sound good that X303 is a good choice. For your rear end, I'd suggest 3.73 or even 3.55 if you're planning on street driving. Also invest in a limited slip diff with carbon fiber clutches or a locker. Also, I would advise against the HV Oil pump unless you get an ARP pump shaft. As far as I'm concerned, all HV pumps do in a ford is rob power. I run a 302 and a 351W both at 6000+ rpm for 15 minutes at a time racing a circle track with a 5 quart pan and a stock volume pump and don't have any problems whatsoever.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Jun 27, 2007
  • Jun 27, 2007
No need for a high flow fuel lines, the stock ones support plenty...
Have you considered a custom cam over the X303? It will just be another $130 bucks or so...for better power throughout and driveability...
Get a 75-80mm MAF, they flow plenty...and a good aftermarket throttlebody (Accufab, Holley, Edelbrock, BBK). 70mm would be plenty of cfm for the engine.
Everything else looks good...
Oh, you really don't need a HD oil pump, or really a HD water pump. A stocker would be fine (water pump), as long as your cooling system is in good shape.
Good Luck, sounds fun!
W
wickdgt
15
Flint, MI
Jun 28, 2007
  • Jun 28, 2007
Thanks for the comments. I have already purchased a standard oil pump but was thinking about going for the HV. Maybe I'll just keep the standard. Any input on the intake? I know that cobra is going to give me too much flow restriction. Thanks again.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Jun 28, 2007
  • Jun 28, 2007
It will be a restriction, but your car will still make lots of torque/horsepower down low...
A Holley Systemax may not be a bad idea...
You could port the Cobra lower and maybe have the upper touched up by a very talented intake porter on this website. He goes by tmoss. He did my lower intake, and did a great job, it is around $130 bucks or so, but well worth it in my opinion.
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
