I need head and cam suggestions from the knowledgeable one's.
Here is what I'm working with. 306 roller block, decked & balanced. stock bottom end, speed pro pistons, All msd ignition, Performer RPM intake (carbed) 650 DP. 1 5/8 Longtube headers Car is ~3100lbs. T5z trans and 4.30 rear gears. Will be run on 26-28 inch slicks still unsure.
I need cam and head suggestions. I know there are guaranteed combinations that will get me there, such as AFR's with matched cams.
I'm thoroughly confused because I keep researching different combos and flow numbers, cam specs, compression ratios etc... and I don't know what's right for me.
I don't want to dish out $1300 on AFR's if I can get say edelbrock performer RPM's slightly used for $900 I'm just confused because I'm looking at all these different heads and don't know what's right for me.
As far as the cam goes, I don't want to go too drastic, something around 224-230, maybe something from comp cams. I still need to pass emissions testing so too much cam won't help.
Any ideas??? All thoughts appreciated. Once the motor's in and running I plan to upgrade the stock fuel system and throw on a small shot of N2O
