I have the PS3 kit and I am having problems with the set-up. The stock AFR spring installed height that the heads originally have is 1.800-1.815. Ed Curtis set up the PS3 kit with shims that will get you .030 longer than the stock height. So since the kit shims off of the stock height the installed height for the new springs is 1.830-1.845. So here is the problem. My origional-installed height is around 1.775-1.785 which is too short according to specs. So when I install the kit as prescribed in the instructions it sets my installed height .030 longer than stock which since my stock is actually 1.775-1.785 it now sets the PS3 springs to 1.805-1.815. This is far under the suggested 1.830-1.845. I don't know why the original installed height is so far off? I don't know if I should install the kit as prescribed and be under specs, or re-shim every valve to get the suggested 1.830-1.845? Ed Curtis is on vacation and I need to get these heads together.
