  • 1994 - 1995 Specific Tech
AFR165 users: answer asap!!
  • Thread starter Thread starter homerojr
  • Start date Start date Aug 23, 2005
H
homerojr
74
  • Aug 23, 2005
Sorry to ask you such a silly question, however, there´s a correct side for the heads (a head for the driver side and another for the passenger side), or they can be installed at any side. Is there an identification or number on these heads to diifferentiate them?
Thanks for any info
AznStanger3v
2,026
Northern VA
Aug 23, 2005
  • Aug 23, 2005
the bolts that hold the accessory brackets...... those holes they go in are your indication
Stangfreak95
add a 4
3,571
In your sister. If none, your mom
Aug 23, 2005
  • Aug 23, 2005
Either side dude. Just put the plugs where they need to be.
H
homerojr
74
  • Aug 23, 2005
Thanks for the help. I was asking because I´m porting my cobra intake to match the intake ports, and so I definetely must get the heads in their respective position. I have p-heads and p-headers, and due to the spark plug position being somewhat diferent, so are the headers (though I was told they would fit on my new heads if I keep them; if some money is left I should go for lt´s). Sorry again, just to see if I got the point: so in the AFR165 the plugs are pointing to the front of the vehicle?
Any picture would be greatly appreciated.
R
rockin_rick
968
Aug 23, 2005
  • Aug 23, 2005
When you get a set of 165's, you get 2 identical heads. Either side. The spark plugs will face forward on the pass side, and back on the drivers.
Rick
Stangfreak95
add a 4
3,571
Aug 23, 2005
  • Aug 23, 2005
Your heads are suppose to come with (2) plugs. Those plugs will need to be inserted in each head on the side where all your pulleys, alternator, power steering are. If you're not gonna run the air pump stuff, then you'll need (2) other plugs to go in the back of the heads, where the firewall is to delete the bracket that joins both your heads together.
H
homerojr
74
  • Aug 24, 2005
Thanks a lot everybody!! I guess I got it right. My setup will be non-emissions, and I´m aware I´ll have to plug the holes at the back of the heads.
Thanks again.
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
P
Air Fuel ratio bung location.
  • Praetorious
  • Feb 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 11, 2026
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
Timing chain, guides and tensioner installation (Possible orientation in Intake Stroke)
  • StallionMax
  • Sep 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 24, 2025
StallionMax
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
