I wrecked my 95 Cobra and just finished rebuilding the car. I plan to start it up Friday. Last night, I installed both air bags. When I turned the key on engine not running the airbag light began to flash. The DTC code is 12 - Lost battery feed. According the the Mustand service manual, the airbag diagnostic module will blow the fuse in order to disarm the system to avoid possible deployment. I check the 10amp fuse and indeed it was blown. The manual also states that the DTC 12 code could have been triggered by a short circuit in the Pin Nos 13 and 14 circuit. I check the voltage at the battery and noticed when I put a load on the battery using a battery tester the needle went into the yellow zone or weak zone. This is a brand new Yellow Top battery so I will take it back to sears. Also, the main fuse feeding the 10amp circuit did not blow. I have the Mustang service manual and will do some additional testing but thought maybe some here experienced the same problem and could shed some light.
1. Willl the weak batter cause a DTC 12 code?
2. What are the chances that the airbag module is bad?
3. The service manual suggest using an airbag simulator to test the airbag system. Where can I get this air bag simulator tool and is it really necessary to use to test the airbag system.
Thanks for any insight. Peace
