Air Fuel Ratio's
Beasly B
165
Virginia
Just learned how to datalog with my lm1 do these numbers sound right? Up to about 4k they are high 12's to low 13's and after that up to 6k they are mid 12's I have my PMS now what could I do to make them better or are they okay?
For my n/a combo I tuned it so it starts at a low 13 across and works its way to a upper 12 up top to 6700 rpm. Try pulling out -2% fuel @ 6000 rpm in high load and WOT.
When you do your blower, you want it in the 11's.
thanks sounds good, friday I ordered 42lbs injectors pro-m blow thru meter and the 3 bar map sensor that was close to 700 bucks hopefully I won't be naturally aspirated for long, really the only thing I have left is the procharger kit and I'm real close but don't want to be in a bind for money so maybe a few weeks I'll be tuning for boost with yall's help. thanks
The rpm converters are pieces of sh it. Mine does the same thing, it isn't perfect when I load it to my computer. Its ok enough to tune though.
And shoot for 11's for your blower a/f :)
If you set up the converter with an inductive pickup, it will work fine. You need not purchase the one from Innovate. All you need is aabout a 12 inch length of 8 or 10 G solid copper wire. Wrap it around your coil wire and run your rpm converter to one end of it. Works great, no muss, no fuss. The RPM converter on the LM-1 is on the sensitive side. This poor man's inductive pickup works great.
