Hey Stangnet tech gurus, my airbag light is flashing 10 times followed by a short pause and then flashing another 10 times, and cycling that pattern. I'm assuming this is airbag Fault Code 10 - Diagnostic Monitor Internal Thermal Fuse - Open Due to Intermittent Short To Ground.
Mustang 90-91 Air Bag Diagnostic Codes
I found the website above that is helpful, but I don't know where to start to fix the problem. Which wires in the harness should I check for broken insulation or contact with metal? Should I just replace the small blue box behind the HVAC controls? If I need to buy a new "blue box behind the HVAC conrtrols," what is the exact name of it so I know what to ask for at the dealership? Is it safe to assume that my clockspring is fine? Any help is appreciated! Thanks in advance guys.
Chris
Chris
