airbag light code 52
stangjunkie
381
Just bought a new car and my airbag light is flashing me a code 5-2, After a little research i found that there is a grey connecter in the passenger footbox, not plugged into anything and im supposed to bridge some pins inside of that. well I found two unconnected grey plugs. one was about centered under the passenger airbag, thisplug only had 4 male pins, the other was at the far left close the the center of the dash, only found after removal of the glovebox. it had probably 10-16 female pin holes this seemed like the logical plug rumored to have to be bridged to turn off the code. I know the code is fairly common it turns on whenever you have a "weak battery conection" wich can happen if you have a weak battery or cables. Can anyone show me some guidence on how i can go about turning off this light as it wont pass inspection with it on. thanks everyone!
