bdcardinal
tree hugger
the specs from MM are good. i run the same caster, but a lot less camber, mostly for tire wear issues. i run about -.5 camber and 4.7caster on both sides with toe at factory. we do not have large road crowns here so thats not an issue.
did you tell the Sears tech that you have CC plates? not all of us know about them. and i can tell you that the alignment machine does NOT prompt to look for plates, it doesnt list is as an optional replacement on mustangs, it only gives the wedges for camber.
